Topic: confused- input shafts (Read 1274 times) previous topic - next topic
so i have a quick question before i buy this input shaft. correct me if anything i say is wrong.... im gonna replace the 3-4 input shaft, now a 3-4 shaft will accept both a lock-up and a non lock-up converter. but if i want to run a non lock up converter, can i just throw one in with this hardened 3-4 shaft? or will i need to replace evreything with a new one piece shaft? i think the 3 and 4 gears are lock up and 1-2 dont so idk if converter type will affect anything if the 3-4 shaft accepts both. it may be confusing, im having trouble trying to explain what i mean. basically i just want to know if i use the 3-4 shaft below, with a non lock up converter will everything be ok?
http://store.summitracing.com/partdetail.asp?autofilter=1&part=PMA%2DPA53401&N=700+4294848183+4294904006+4294848179+115&autoview=sku
1988 Thunderbird sport
2004 Ford F150 Lariat
2008  Chevrolet Cobalt Sport
1988 Thunderbird LX - sold
My understanding from speaking to the guys at Lentech: if you go with a non-lockup converter, you need to go with a one piece input shaft.  Someone else may chime in with specific experience.
Go here and ask. There a guy there that can answer all your questions, He comes on here once in a while. His name is silver fox.
http://www.clickclickracing.com/forums/index.php
Quote from: grutinator;254343
The ONLY non lockup converter you can run with the above(which is identical size to orig), is one designed to be used with the original setup... B&M did market these, dunno if they still do... For a conventional non lockup, the complete front shaft assembly must be replaced...
