Topic: Swapping to a sport cluster???? (Read 1336 times) previous topic - next topic
I've got and 86 with the base digital cluster so the gauges a mechanical in it, so what has to be done for this to work or is it plug in and go I know the oil sending unit is different but anything else like wiring
Thanks
Robert
The wiring is completely different. You'll need the connector off the Sport cluster, and you'll have to re-pin it with the wires from your existing connectors (your base cluster has two, the Sport only has one). You'll also need to get a tach signal to the dash. There isn't one there from the factory.
Sounds like alot work I might just swap it one day but not anytime soon LOL
Robert
