Topic: name this part (Read 2009 times) previous topic - next topic
name this part
It took my youngest boy to discover this ,,, i was amazed at the whole idea.
SO,, name this part in your engine.
name this part
That's clearly a penny valve.
name this part
I'm gonna guess the ball in the oil pressure relief valve
name this part
I am guessing ler bearings.
name this part
Quote from: cougarcragar;253602
:giggle:
name this part
32 eh??? Well they ain't valve keepers, just about have to be the check valves inside a hydraulic lifter...
name this part
Oh that is easy, that is the check ball for the lash adjusters.
James
name this part
call me stupid or whatever but I had no idea that the ends of the push rods had an actual ball welded to the end.  A sharp strike with a hammer and they come off clean.
I always thought the pushrod was a hollow tube press shaped and such as one solid piece.  I did not know there were three parts to a pushrod.
purdy spooky.
name this part
Quote from: jcassity;253621
purdy spooky.
Depends on what the design is as well. Not all are like that.
James
name this part
Quote from: srv1;253623
James
True, most shaft rockers use a cup on the upper end of the push rod... Those are usually solid shafts and the cup and ball are machined in place ... Anyway, since the ball is welded to the rod to form a supposedly "permanent" assembly, it was a trick question...
name this part
Quote from: TurboCoupe50;253617
I was under the impression there was only one per lifter as seen here:
As far as pushrods.....
name this part
hmm it looks like a paper plate ,a penny and 2 bearings from the slide out ask tray,,,but then none of them would be engin parts...oooo wait the paper plate is used for a light weight breather cover ,and the copper is placed under an injector for when the fuel hits the copper it has a chemical reaction to increace fuel econimy.and the to meatle balls are placed in the breather and they swirl around to form a tornado to force air down the intake...good idea magiver
name this part
Quote from: BEARMAX;253655
pass it around man...
