Topic: search function (Read 3891 times) previous topic - next topic
search function
ok, i tried to search for blower motor and got 96 threads, so i tried to search for the phrase "blower motor" and still got the same 96 threads.....  is there a was to search for an exact phrase or will it only search for both words independently?  a phrase search is so much quicker
thanks
search function
try "blower motor repair". you should get 8 good one.
remember it easier to fix them, than to find them after they been crushed.
V6 = juvenile delinquency!
search function
i know, but it still tries the words individually.....  would be cool to search for the exact phrase :)
search function
yes, it would but then some of us, would be cofuzed
search function
hmmm....  i thought searching by exact phrase was in the advance options. guess not.
search function
im still not really sure how to separate key words.  I just type a word or phrase and depend highly on the thread title.  thats why i hate thread titles like,,,,,"darn it" or "opps"  when in reality said threads are about specific problems.
search function
Try wrapping quotes around the phrase you're searching for, like "blower motor repair". Most search engines will return the exact phrase if you use quotes.
You can also try using plus signs between the words. blower+motor+repair will return results will all three of those words, but not necessarily in that order (it might return results like "repair blower motor"). This will prevent you getting every thread with the word motor in it.
search function
i thought the comma would do what you say the plus sign does??  learn me something new please.
search function
yu is been learnded
search function
Quote from: jcassity;253603
Ok...
The comma between words means that all the words do not have to show up in the results, such as searching for thunderbird,cougar on eBay would show all results with thunderbird OR cougar. The plus sign means thunderbird AND cougar, so any results showing only one or the other would be omitted.
The minus sign (-) between words will omit the word after the sign. For example, to stop seeing Chevy 305 engines when you search for "5.0" on eBay you can type "5.0-chevy" (without the quotes).
...Also, you can use brackets to do many searches at once. A common one I used to do on eBay would be somthing like (1983,1984,1985,1986,1987,1988)+(thunderbird,cougar,tbird,t bird)-(decal,decals,cl4d,chip,turbonator)
This would bring me all results for 83-88 T-Birds and Cougars but omit all the decals, resistor-sold-as-a-performance-upgrade scams, turbonators, and a particular seller that used to spam up the results with hundreds of ads (for some reason all his ads had c4ld in the title, so I could ask eBay to ignore it).
I say "Used to use" because with eBay's supremely stupid "Best Match" search system anything you search for is a  shoot.
search function
...of course I'm using uiniversal search variables (will work with Google, eBay, etc). I have no idea if they work the same on this forum. I've never tried it :D
search function
The + and " don't turn it into phrases in our search engine here....
However, go to google and type:  site:http://www.foxtbirdcougarforums.com "blower motor"
The results are narrowed to 30...
search function
Quote from: jcassity;253510
:iagree:
It helps folks search threads and scan sections if people put a little thought into their thread titles.
