Topic: seat switch (Read 1471 times) previous topic - next topic
seat switch
how do you convert your car from single electric seat to dual electric seats?
seat switch
The seat harness unplugs, next to the drivers seat by the doorsill. You need the dual seat harness, the power pass seat track and the switch,. Of course you can just get the seat track and switch and just wire it into the wiring for the drivers seat also. :D
95 Ranger Splash 2.3
88 Tbird Sport :ies::ies:
seat switch
i got a dual seat harness from a 88 turbo coupe and changed the plug so it would fit my 84. then plug in all the switches and the driver side works but the passenger side doesnt. also from looking at a dual seat wiring diagram then matching it up to my wires everything is hooked up right i know i am getting power because the two black wires you can touch together and they will spark but with everything plug in like the switch nothing.
seat switch
There should be 2 plugs on the seat? are they both hooked up?
seat switch
what do you mean two plugs? do you mean the switches that control the seats or two main plugs?
seat switch
There should be two plugs on the harness at the seats.
seat switch
I'm guessing these 2 plugs.
seat switch
if he is talking about two switches underneath the passenger seat then i dont have that instead i have two relays. one goes to the power locks and the other one i have no idea.
seat switch
Quote from: daminc;252818
Never mind, that's a pic of the relays.
I think the connector got wedged under the front seat in that pic
