Topic: DSS 331 kit (Read 859 times) previous topic - next topic
DSS 331 kit
posting this for a friend.....
I have a DSS 331 cast crank, forged i-beam DSS rods, and 6 DSS forged pistons
Comes out to 331 cubic inch stroker for 5.0 based block.
Motor ran 11.80s@115 with Dart Pro-1 cylinder heads, comp xe274 hydraulic roller, and Victor 5.0 intake at 3200 lbs race weight in street trim.
2 pistons were damaged when the block cracked (no nitrous use, just cracked). I looked at the two pistons and it appears that they cracked between the ring lands. All other pistons are very clean, rods are clean, and crank is clean.
Buy two pistons, rings, and bearings and a 5.0 block and have you a nice 331 stroker.
Price is $600 for the complete rotating assembly (including the two cracked pistons which you can buy through DSS)
carl_smith@oxy.com
located in Baytown, TX 77520
1979 Ford Fairmont
[/B]
