Topic: Oil idiot light acting...well like an idiot (Read 836 times) previous topic - next topic
Well on my 86 5.0 cougar there is a sensor just forward and above from the oil filter on drivers side.  it was leaking just under the nut below the 1 wire connector.  what the sensor is i dunno exactly but i had the guy at the parts house look at it and grab one for me.  I just did an oil/filter change and changed the sensor out.  now every time i fire the car up the idiot light stays on constant lol  what gives?!?
Wrong or bad sensor?
That is the oil light switch.  It's not a sensor or sender.  If he grabbed you one for a gauge instead of a light, it will be the wrong one.
or there's low pressure and the light works
ok... i just checked the part number from Niehoff.  shows up Oil Pressure Gauge Sender,  application for thunderbird 88-81  and cougar 88-85
guess i better get another one?  or install an electric gauge?
