Topic: fuel question (Read 861 times) previous topic - next topic
fuel question
Is a fuel pressure regulator the same as a fmu? if not what is the differance?
fuel question
basically its a fuel pressure regulated by boost.
1979 Ford Fairmont
[/B]
fuel question
concur, w/ 32V....before there was a boost referenced fuel pressure regulator, the Fuel Management Unit (FMU) would sense boost and spike the fuel pressure to the injectors. It is old technology and should not be available for any newer boosted applications, unless vortech is still using them.
fuel question
so for a nitrous setup or h/c/i i should use the fuel pressure regulator instead of a fmu.
