Topic: window fell off, adhesive worn out. (Read 4083 times) previous topic - next topic
I spent many a day trying to glue my windows back into the clips.  I tried everything Silicone didn't work (of course it was old and I didn't scratch the window up), Gorilla Glue, (don't bother with that as it won't work at all) in the end I used 3M's window glue and it's holding fast now, no problems.  Yeah it's like $16.00 for the tube (caulk gun size is all you can get this in) but it worked.  As Kitz Kat said, don't get this stuff on your hands cause it took me like a week to get it off (I should of wore gloves :punchballs: ) what a pain it was.
[SIGPIC][/SIGPIC]1987 Turbo Coupe
LenTech Strip Terminator Valve Body AOD, 302 Stroker (cid 347) 10:1 Compresion
Ford Racing Cast 3.40 Crank Balanced, Pioneer Forged 5.4 Rods, Mahle Flat Top Pistons 4.40, Edelbrock Performer RPM Alluminum Heads
Ford Racing 220 Duration 500 Lift Cam, Edelbrock Performer Intake Manifold , Edelbrock 800 cfm Performer Carb
Flowtech Headers, KYB Adjustable Shocks, Dyna Max Exhaust
355 Posi Rearend
my window weld came off last night I think. I messed up where I marked my tabs, so I think I moved them to far forward or backwards on the window. I guess I'l have to do it again...
I broke down the last time and bought a tube of expensive glass adhesive silicone.  It's the ONLY thing that has lasted more than one winter other than the OEM stuff for me.
If you need replacement window clips, They are identical in many Ford and Lincoln vehicles if you want to look and have a salvage yard nearby.
Frozen windows do have a way with pullin the glass out of the clips.
Vin, you know the name of that adhesive??
This was the first thing (among EVERYTHING) that went wrong with my bird.  i tried gorilla glue, silicone, anything i could find.  Finally, i got 3M Windshield glue, never had the problem again, even with broken clips... all 4 are broken.. 3M windshield glue.
