Topic: $200 Dollar Fun (Read 6019 times) previous topic - next topic
$200 Dollar Fun
So here is my some what recently acquired $200 dollars of fun. It's an 1988 with a 3.8 V6 with a bad automatic tranny (no fluid in it). I plan on gutting the car and racing it. I have a 289/C4 set up out of my 65 Mustang I plan on putting into it. Here are the first set of pic's.
Whoa, that was fun!
$200 Dollar Fun
Second set of pic's...
Whoa, that was fun!
$200 Dollar Fun
Engine pic's. With air cleaners for when driving down the road and the stacks are for when I am racing.
Whoa, that was fun!
$200 Dollar Fun
sweet sounds like it will be fun!
~John~
$200 Dollar Fun
Interesting to see that it has cornering lamps. Cool.
$200 Dollar Fun
Yep, looks like fun to me. So what all is done to the motor besides the tunnel ram?
Matt
$200 Dollar Fun
Ported/polished heads, Isky cam, bored .060 over, Forged pistons, moly rings, roller rockers, balanced rotating assembly. Currently has a Mallory dual point distributor, but plan on up grading to an MSD unit. The Mallory looked more period correct in my 65 Mustang. Re worked Holly 450's and shorty headers.
Whoa, that was fun!
$200 Dollar Fun
Not much of an update, but started gutting the car. My next step will to be building and adding the sub-frame connectors.
Whoa, that was fun!
$200 Dollar Fun
900 cfm for a 289???????????
Wow you must have one heck of alotta cam,large port work done to those heads and 13.1 compression if your running that much cfm on such a small cube engine.
Shouldn't need more than two 300cfm 2 barrels for a 289.
Nice looking engine though.
$200 Dollar Fun
Bet Jerry wishes his was that clean when he started!
$200 Dollar Fun
Dominator, yup 900 CFM is correct. I called the Holly and gave them all of my spec's. They said I should be running anywhere between 900 to 1200 CFM.
Whoa, that was fun!
$200 Dollar Fun
Took out the dash today (I do plan on putting it back in). Soon I'll be taking out the heater box assembly. I removed all the heater duct work from behind the dashboard.
What have people been doing/using to fix our dash tops? Mine has a bunch of cracks in it.
Whoa, that was fun!
$200 Dollar Fun
An aftermarket wiring harness would save you a bunch of weight also.
$200 Dollar Fun
Look at all those wires.......:confused: :dunno:
Me and wires just don't get aloooooong:punchballs:
[SIGPIC][/SIGPIC]1987 Turbo Coupe
LenTech Strip Terminator Valve Body AOD, 302 Stroker (cid 347) 10:1 Compresion
Ford Racing Cast 3.40 Crank Balanced, Pioneer Forged 5.4 Rods, Mahle Flat Top Pistons 4.40, Edelbrock Performer RPM Alluminum Heads
Ford Racing 220 Duration 500 Lift Cam, Edelbrock Performer Intake Manifold , Edelbrock 800 cfm Performer Carb
Flowtech Headers, KYB Adjustable Shocks, Dyna Max Exhaust
355 Posi Rearend
$200 Dollar Fun
Quote from: CustomT;252472
Piece O cake...
