Topic: Keyless entry... (Read 3660 times) previous topic - next topic
Keyless entry...
Where can you find the code for your door? Is there a way to re-program it? I plan on having the door locks fixed some time tommorrow and I think that would be the shiznits if I could get it to work.
Keyless entry...
I found my code on a card in the glove box, I tryed to reprogram it didn't work for me, just the original would work.
Keyless entry...
I read somewhere that the code is supposed to be on a tag stuck to the trunk support where all the electronic modules are located
Keyless entry...
on my 88 TC the code is on the RH trunk support and on the keyless module in the trunk under the package tray
 if I remember right the keyless module is on the left side of the back of the backseat you will need to pull the panel down to get to the module
Keyless entry...
On my 87 turbo coupe which was just sold, yahoo, it was on the passenger side trunk support. Just as 88turbo said.
Keyless entry...
thanks guys.
