Topic: CC plates (Read 1767 times) previous topic - next topic
CC plates
I searched about 50 pages can't find the info.
Can an 87 use stang ones with stang struts, I didn't think so , But I can buy them cheaper.
CC plates
http://www.maximummotorsports.com/
"Product Search" for
1983-1988 T-Bird and Lincoln Mk VII Caster Camber Plates
CC plates
Why won't mustangs work? Holes don't line up? I'm curiuos.
They can't be that far off.
CC plates
http://www.coolcats.net/tech/advanced/castercamber.html
it basically says its pointless to use mustang ones since ours are the same price... I dont know why they wouldn't work though...
CC plates
Quote from: Kitz Kat;249463
The holes don't line up. They are close though.
CC plates
Quote from: Haystack;249467
Because I got a cheaper price on stang ones. If it's just enlarging a hole here and there , It would be worth it.
Besides I'm learning more each day, That gets scary!!
CC plates
I used fox style CC plates and the only hole I had to modify was the front hole on each side. No problems at all with the rear two.
[SIGPIC][/SIGPIC]http://www.fquick.com/slicksport88
88 Sport - 5.0HO, Mass Air, A9L, 73mm C&L meter, BBK CAI, 255 lph pump, 1.7 roller rockers,Professional Products damper, Chuck W motor mounts, BBK shorties & H-pipe, Flowmaster 40 series, 8.8 rear w/3.27's, 93 Cobra M/C, BAER 13in. drilled/slotted rotors front and back, cobra calipers, Russell braided brake lines front & back, C/C plates, 03cobra rims, 255/40/17 Nitto 555's all around
CC plates
Quote from: 88turbo;249501
what are the benefits of CC plates anyways? and can they be used with the prc struts?
So you can alighn the car if you go to far from stock height.
Prc's are a seperate situation.
CC plates
Come on Chuck you know! Help me out.
