Topic: Show me your gauge's (Read 4168 times) previous topic - next topic
Hi! Im looking to put some Autometer gauge's in my 88 T/C. Looking to get a Boost, Fuel press, Air/fuel. I would like to see your setups also what year of mustang Apillar gauge pod can I use?
Thanks for your time :burnout:
I used a Fox Mustang 3 gauge pod.
cut 2 holes in my cig light panel for 2 gauges and on in the floor shift panel and then got a sn95 Vert 2 gauge pod a pillar heres a few pics. hope this helps you can buy pods or just cut holes in all your panels its 100% up to you.
Genuine Ford gauges.I wouldn't trade them for any aftermarket stuff.I just really like them.................By the way,the dust has been cleaned off of the dash since these pics were taken..................
t3skidoo,
Very nice I really like that Do you have an updated pic of that setup?
Also stupid question what years is an sn95? and what does it mean?
Thanks
SN95 refers to the last(?) generation of Fox Mustangs.
I'm in the process of slowly putting the interior and trunk back together.  After the new dash pad is installed, I'll post some more pics.
__________________
Twin '85 TCs
White/ Grey 2-tone
Sorry SN95= 94-98 Mustangs
Not the Fox body style
Eric and Gumby i hate for making me look bad just joking both of you got nice set-ups i would trade my stuff out but i kinda like it and ran out of $$$ so i am happy with mine.
This is what I had "back in the day"
I used the Nordskoq Performance Digital Gauges
Nordskoq M9222 Digital Performance Speedometer
3 3/8" diameter.
Programmable, 200 mph speedometer with LED bar graph, digital readouts, odometer with trip.
Easy one button calibration. No screwdriver or pace car necessary.
Can be calibrated as many times as necessary for gear ratio and tire size changes.
Recalls high speed, 0-60 mph time and 1/4 mile ET.
Works with most existing electronic speed sensors.
Transmissions equipped with mechanical cables. Requires S9013 Sender.
Available in High Brightness Red, Green, Amber or Blue display
[SIGPIC][/SIGPIC]1987 Turbo Coupe
LenTech Strip Terminator Valve Body AOD, 302 Stroker (cid 347) 10:1 Compresion
Ford Racing Cast 3.40 Crank Balanced, Pioneer Forged 5.4 Rods, Mahle Flat Top Pistons 4.40, Edelbrock Performer RPM Alluminum Heads
Ford Racing 220 Duration 500 Lift Cam, Edelbrock Performer Intake Manifold , Edelbrock 800 cfm Performer Carb
Flowtech Headers, KYB Adjustable Shocks, Dyna Max Exhaust
355 Posi Rearend
Quote from: CustomT;249234
That looks expensive.
