Topic: Balljoint (Read 1250 times) previous topic - next topic
Balljoint
I have an 88 sport coupe with 95 front brake conversion and lincoln rear I've put fox mustang a arms in and struts but I used sn95 v6 mustang springs to lower it and be able to get the rebound like some do with fox 4 cylinder springs not sure how much drop ill have yet my question0is a bout balljoints what kind are you guys running on you lowered foxes
Balljoint
You can use the fox balljoint but with the SN95 spindles you will
have to use a lg spacer(washer) between the spindle and the nut
for the castlated(sp) part to be up high enought for the cotterpin
hole?
 Hope this makes since?  Or use an SN95 balljoint and a nylock nut
Balljoint
That's what I did with the brake conversion with the spacer but what I was meaning is when you lower a sn95 they say you should use steeda x2 balljoints it does something for a lowered car and I didn't know if it was the same on a fox body
Balljoint
The ball joints are interchangeable.
 I just never could justifiy the steeda over a replacments
