Topic: c4/c5 ?? (Read 1482 times) previous topic - next topic
c4/c5 ??
I was wondering if the pump, input shaft and planetary from a C5 will swap into a early style C4.
 Can someone tell me what the real differences are between the C4 & C5
Thanks
Doug
Happy Holidays.
c4/c5 ??
A C5 is essentially a C4 with a lockup converter and metric fasteners. Because of the lockup I'm doubting anything on the input shaft end of the tranny would interchange...
c4/c5 ??
Pump....Maybe. Anything else. NO. You would have better luck attempting to use it in a AOD.
c4/c5 ??
Accualy the C5 has a messed up centrifugal lockup system...real gay.  i HIGHLY suggest swappping the C5 vb out for a C4 unit and the C4 bell....that is the best stock option you can do :)
------------------------- Dan Gilsdorf ---------------------------
c4/c5 ??
I was told that not all c5's had lock up converters? Does anyone know the difference in bell housing from the C4 to C5. Or maybe the difference in converter size.
 For the vb, Im assuming its out of the new C4 rather than the older C4. Is that a direct swap or is there modifications needed.
c4/c5 ??
preffered VB is 70+ yes
there is like 200+ bellhousings...crazy discusion :D
c4/c5 ??
Quote from: Douglas Walker;249597
 the only c5 differences that I'm aware of was the size of the torque convertor and high altitude models, but what they are I do not know specifically?
