Topic: Polishing Centerlines (Read 1087 times) previous topic - next topic
Does anyone have any experience with polishing Centerline wheels?  I have a chance to pick some up at a reasonable price but would prefer a more polished look.  Any help would be appreciated.
this and a mother ball and they will look brand new, I hawe used a lot of different polishes and this is by far the best and the best price on it.
http://www.thezstore.com/page/TZS/PROD/OGCCP/80-8112
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
If they are polished aluminum without any type of sealant on the surface (Zoop, etc.), they should react like any other polished metal.
It just takes time, the right materials and a good technique.
I've spent countless hours polishing aluminum parts until they looked like chrome. The Centerlines should be fairly easy to do, unless they have caked-on brake dust, salt/corrosion or other detritus.
You might consider buying the Mother's Power Ball.
My favorite products are Mother's Mag & Aluminum Polish (paste) and Nev-R-Dull.
Depends on the tools you have access to. I had access to a lathe I could mount my 10holes into. Then I cut a jig the shape of the surface of the wheel. Then covered the JIG in Gray scotch brite pad. Then Mounted my jig on the tool rest of the lathe. Then turned the lathe on and turned the tool  until I added some pressure on the jig piece and made sure it was making even contact. Let it run that way for 1hr then pulled it off the lathe and went to town with a power ball Came out real nice. I have a thread on here some where showing what it made the first one look like after the lathe treatment!
