Topic: rear chassis crossbrace (Read 3054 times) previous topic - next topic
My TCs have a chassis crossbrace just in front of the axle, dunno if all Birds/Cats have them or not.
There's a brace on the inside under the carpet that saddles the driveshaft tunnel.  It looks like that inside brace is loose.  Is there anything to reinforcing that brace, welding it solid, and/or replacing it with something else?
__________________
Twin '85 TCs
White/ Grey 2-tone
this one?
yup, that's it (the inside one, of course)
__________________
Twin '85 TCs
White/ Grey 2-tone
You could get a nice piece of 1/8 x 1 steel and replace that if you wanted. or put more bolts in the one you have to tighten it up.
Really comes down to how much more you want to stiffen the car up.
If you aren't worried about twisting the car, just bolt it back in.
okay, thanks
__________________
Twin '85 TCs
White/ Grey 2-tone
I think the inside strap is mainly a strong mounting point for the studs that go through the floor so the under-brace has something to bolt to. It also helps retain the under-brace in case a u-joint lets go and the brace has to act as a "driveshaft safety loop".
Yea, pretty much all it does.
I'm going to make one that bolts across my crazy SFCs. That will tie them together.
The brace that's under a 3.8 car, doesn't hang down enough for the pipes to go through. I need to change mine anyway, along with the transmission cross member. I may make one of those too.
interesting mark vii's have those too. i just pulled all my interior and didnt notice the brace in the car though.
Quote from: mark007;247625
It might be hard to see if there's a lot of the tar insulation.
__________________
Twin '85 TCs
White/ Grey 2-tone
Did some thinking on this.  It would be nice to tie the subframe connectors together instead of relying on the floorpans, but it's also probably a good idea for that brace to be removable.
How about a tubular bar with a dip in the middle for the exhaust (similar to MasterBlaster's pic) with heim joints at each end, or is there a simpler way?
__________________
Twin '85 TCs
White/ Grey 2-tone
What kind of SFCs do you have now?
I'm thinking about bolting my rear brace to them
The SFCs came from somebody on TF, I think Bob40 is selling them now.
__________________
Twin '85 TCs
White/ Grey 2-tone
Quote from: t3skidoo;247730
Heim joints are not a good choice for something that needs stiffness in bending or torsion. Mounting points like the MM K-member braces are the way to go.
Heim joints are also a bad choice for strut tower braces.
oh yeah, that looks better and simpler.  weld a couple of tabbecd mounts to the insides of the rails, fab a bar, mount some bolts with bushings in them.
__________________
Twin '85 TCs
White/ Grey 2-tone
No need for bushings.
