Topic: stock equalizer question (Read 4355 times) previous topic - next topic
My car is factory premium sound- no EQ.
Are the plugs behind the storage panel to just plug in?
Or is it something harder?
Thanks
Mike
Nobody has done or pondered this before?
Mike
I've pondered the question, but I'm really new to these and the TC is still on the lift with another car under it
5 Mopars, an S-197, and the Turbo Twinkie[SIGPIC][/SIGPIC]
check this out.
http://www.foxthundercats.com/samscars.htm and go to the wiring diagrams.
definitely not the same
The plugs are there, they are tied up. Make sure that you are looking in the correct place in the trunk behind the rear seat, drivers side.
Im talking about hooking up a factory EQ in the factory location in the dash, of a car that didnt come stock with the EQ??
Mike
Mine has the EQ and I was under the impression that you need a non-EQ head unit to connect it up. That HU doesn't have a fader because the EQ does, and it comes with a specific  plug to work with the EQ.
Course it doesn't really matter, do a search here and you can see how to splice it into your system, plugs not needed. I got my EQ to work with aftermarket HU/AMP/Speakers, etc thanks to a few people here and I LOVE IT.
pro-five-oh
Stock EQ
Did your ever find more information on adding a stock EQ?
I just got one a pick and pull today. I also got the stereo with it .
No, I never messed with it any more, just plugged in a used Alpine 12 disc changer, Ive been happy with it for now.
Mike
Quote from: Greg Price;288721
Did you ever try it??  :D
Mike
It looks like the factory amps were different.  With the EQ it has all 6 speakers coming off the amp.  W/o EQ only the front and door speakers off the amp.
Do you have to swap the amp also?
Was the amp/w eq higher wattage??
Mike
