Topic: 93 gas? (Read 1200 times) previous topic - next topic
93 gas?
ok so i put some 93 gas in with my 87, now its running like shiznit. is that why? i wanted to clean out the fuel system
93 gas?
Thats weird. I run 94 in mine every once in while and seems to do better. Got me.
85 Tbird 5.0
78 F150 351w
13 F150 4x4 3.5 Ecoboost
93 gas?
well, when i stomp on the gas, it sputters sometimes.
93 gas?
Higher octane fuel burns slower...slower flame front propagation, that's why the higher the compression ratio or with added timing, you'll need to run higher octane.  These cars were meant to run on 87...I ran 100 octane in my old 'Bird with the HO motor and 14* timing...like you described, ran like ....FWIW...I did NOT want to run 100 octane, but I made more passes that night than I thought and it didn't look like I was going to make it very far on what I had left in the tank.  HO motors will run okay on 93 and 94, but that's because they have more compression than the SO.
Hope that helps,
Don
93 gas?
thx :)
93 gas?
Could be bad gas too. Most of the places where gas is expensive is where I get the worse gas mileage. Also, around here, we get gas at Maverick gas stations at work, and they go through fuel pumps like no tomorrow. At least one or two every year.
93 gas?
I don't run less than 98.
Just because!
93 gas?
93 is better cleaning fluid that 87?
93 gas?
If you want to clean it out, throw some sea foam in it. Or a little bit of alcohol.
93 gas?
Quote from: Haystack;247026
:drink: moonshine will cure anything...LMAO. I'd have to say water in fuel, there's 2 stations around here at the bottom of a hill, put in 93 octane truck hated it, went through it like water. however it loves the local shell 93. Wierd
