Topic: manifold Bolts (Read 1159 times) previous topic - next topic
manifold Bolts
Does anyone know where I can buy the manifold bolts for an 87 5.0, the ones with the non removeable nut which allows you to screw the stud into the manifold. I tried double nutting the new threads I just bought, but about half way up they seperate.
I dont have to have to take the manifold out of the car...
manifold Bolts
Bump. anyone have any idea what I'm talking about? How have you guys put new studs into the manifolds?
manifold Bolts
Intake? Exhaust? Upper? Lower?
manifold Bolts
exhaust. The ones which connect the manifold to the ypipe.
manifold Bolts
Dorman probably sells them. Check out their website
1988 Thunderbird
306 HO w/ A9P processor
AOD w/ Transgo Reprogrammer
245/50/16 Tires on Snowflakes
manifold Bolts
9/16th head coarse thread I think. Go to home depot and get some either all`thread or find some bolts the right length. I'd buy a 12" all thread that a 9/16th nut will fit on. Test it on the head. Put a bolt on the all thread after its screwed in, cut it with a dremel or grinder right after the nut. bring it back to home depot and buy the bolts that are the same length from the nut the the end of the all thread.
manifold Bolts
Oh there different lengths if you have a stock 5.0 manifold. Headers I think are all the same size.
