Topic: looking for door pillar trim (Read 770 times) previous topic - next topic
not sure what years will work, but I just looked at mine and they have several dents in them and I would rather just get another set.I need all four thanks.
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
Are those pieces from the body (right ahead of the quarter windows) and from the doors? If so, we may have pieces from the body. Also if so, how did you get them off of the doors w/o wrecking them?
1987 Turbo Coupe - Son's car
1934 Ford - My project car
very strong fingers lol, you have to pull back towards the rear of the car for the front ones. the back ones 3 screws and snap clips on the window
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
Yeah, I've pulled the back ones off before, but have never had amy luck getting the door pieces off. Maybe I need to heat them, so the adhesive softens up. Anyway, I plan to start stripping another 87/88 TC over Christmas. I will see what I can do on the trim for you.
They have clips on the 86' maybe the 87-88 are different
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
Geez, I need to pay attention. We only have 87/88 TC parts, so I "assumed" 87/88. I don't know if they're interchangeable, but I'll still see what I can come up with.
87 has trim adhesive
http://www.foxtbirdcougarforums.com/showthread.php?t=20802
bump
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
There is an 83-84 Bird at the yard. Ill look fo you this weekend. I have a feeling they are dented
bump
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
I got 88's,
