Topic: overheating troubles (Read 4015 times) previous topic - next topic
hey guys i replaced my thermostat, and its still overheating like a bitch. could it be a clogged radiator? it seems it only overheats on longer trips id say above 20 miles. but then again it only overheats randomly. i replaced my thermostat and coolant, could it be anything else like a clogged radiator? its been sitting for 6 years like i said before. any help is appreciated.
May be the heater core
FOXLESS!!
1994 Lincoln Mark VIII
how do you figure?
Well really its just an educated(sort of) guess. I dont really know why it would be but i had a '92 taurus that acted up like that and someone had mentioned it could be the heater core  so i just bypassed it. Never had that problem again. But as you said it could be a clogged radiator. An easy way to check is to pull the top and bottom main hoses ( they are like inch and a half or 2 inch) from the water inlets in the engine ( dont remove them from the radiator) take a waterhose and run water through the top radiator hose and let it come out the bottom - you will know if it is clogged and it will half ass flush it too.
FOXLESS!!
Then again sometimes parts from the autostore come faulty, try another thermostat
FOXLESS!!
oh thank you
also today i just opened up  my radiator, it was very low, bu then again i just replaced the coolant and all that, could it have "burped" out the air and all that space needs to be filled up again?
Possibly. What I usually do when I replace my coolant is fill it, then let it run with the cap off and if it goes down I fill it while its running to help get rid of the air pockets. I'm sure theres a more proper way but this works for me.
85 Tbird 5.0
78 F150 351w
13 F150 4x4 3.5 Ecoboost
well when i do that, it spits all the antifreeze out of the top of the radiator, well more like pours it back out, could there be a hell of a lot of air in there?
Yea same here seems to work fine
FOXLESS!!
alright cool
took it for a test run, does something interesting, it seems to cool down when the rpms go up
rpm or speed?
5 Mopars, an S-197, and the Turbo Twinkie[SIGPIC][/SIGPIC]
rpm i believe, but when it sits and idles it gains a lot of heat, but when i start moving it cools off and when i turn the car off i hear it bubbling in the reservoir
check to see if any water is coming out of the wheeping hole in the waterpump. It could be a blown head gasket, or radiator as well. I would bypass the waterpump all together just to make sure its out of the equation. If you have a clutch fan, stick a bolt in it. If the clutch is screwed then the fan could not be working as well.
