Topic: smog pump, a/c, clutch fan.... (Read 2044 times) previous topic - next topic
If you remove the smog pump, and the a/c compressor would it make the car faster?, i know it would be less strain on the engine having 2 less pulleys, and a little bit of weight loss, but would it really make much a difference? And how hard would it be to find a belt after doing so? One more thing, if you remove the clutch fan and add an electric fan would the same prinl take effect(less strain on the motor)? :confused:
FOXLESS!!
1994 Lincoln Mark VIII
yes but not much. Smog pump is 1 hp on a dyno. The Ac is basically just a pulley when its not engaged, so I would guess 1 hp or less. The fan I could see some drag being on it. An electric fan requires a 3g fan, fan controller.
couldnt you rig a fan to a toggle? or would it burn the motor out too quickly?
FOXLESS!!
And really it sounds like too much work for such a small gain - just a thought
FOXLESS!!
Quote from: Haystack;246341
plus weight is horsepower too. if you weight those parts, that how much less your car is.
(so in the1/4 mile race or street that will make your car faster because it don't have to push as much weight to get going).
 extra plus there less weight on the front wheel for weight transfer and your weight bias from front to rear is better, for handling.
remember it easier to fix them, than to find them after they been crushed.
V6 = juvenile delinquency!
Generally 100lbs = 1/10th of a sec on the 1/4mile
So the weight plus the tiny gain from less drag might get -0.005 quicker time.
But the time and money spent will proably out weigh the benifit.
I bypassed mysmog and a/c by ussing a smaller belt and left the parts on so come inspection time I can reconnect the smog.
My bearings are going bad in my smog so I needed to.
~Rich
92 T-Bird 5.0HO(yeah I know it is over an 88 but I like this forum :D )
Upgraded exhaust 2.5" to3" to 2.5" duals and single 3" hi-flow cat, deleted smog and a/c, cold air,ported mass air(for now).
upgrades to come-T-5 swap,3.73gears,Gt40p intake&heads,cam.
Where(or really how...) would you find a belt for it?
FOXLESS!!
Quote from: 20thanniver-ls;246451
Wrap a string around it and measure the string.
Switching to an electric fan is not zero load on the engine. More electrical load on the alternator makes it harder to turn.
well i know its not zero load but it seems like it (clutch fan) would cause more resistance to the pulley system and drag the engine down more than a higher electrical load on the alternator would. Im not really saying im going to do any of this (yet) im just going through ideas in my head and throwing them out there to see what you guys think - most of you are quite a bit more knowledgeable with these cars than i am:bowdown:
FOXLESS!!
do a search. It has been covered many times. I just barely posted up a belt routing diagram, including how to bypass things if you just look around.
Quote from: 20thanniver-ls;246456
A clutch fan is actually better on drag than a normal fan.
On the fan idea.... the tiny bit that you might gain(maybe 1hp at peak rpm) would not be worth the time. Now eliminating the a/c and smog might get you a couple(most of it being the loss when the a/c is on).
Also the elimination by using a short belt is actually quite easy and generally cheap. I think on yours it was a 76 or a 79 inch belt.
Mine was 85.5 6rib belt but mine is a 92.
I myself would not even take off the smog because when you have to get it inspected you might have problems. I kept my old belt in the trunk for inspection time and come spring I will get one to get my a/c back.
~Rich
When I did the E-fan in my old 'Bird, I did an underdrive crank pulley at the same time...picked the pulley at a J-yard for next to nothing....just those two things gained me 3 more mpg and I dropped 2 tenths at the track...probably would have been more if I wasn't going into a steady 25mph headwind with 35+ mph gusts.
But yes, you'd need to do a 3G alt swap which isn't a big deal...if you do a j-yard E-fan set up, you'll be using a lot more amperage with a stock type fan from another vehicle...I have a flex-a-lite fan set up that pushes 3300 cfm(way more than enough) and only pulls 18 amps peak...most stock type fans (taurus or mark VIII) pull a heck of a lot more amerpage...less amperage draw=less strain on the alternator=less parasitic loss.  And just about anything is better than the junk clutch fan.
Good luck,
Don
