Topic: Belt for smog & a/c deletion on a 92 (Read 868 times) previous topic - next topic
I know that most everyone on here runs 88 and under but I have a 92 5.0 T-Bird and have a bad smog pump.
I found that a 855K6 Duralast belt 1/2" larger or smaller will work too. I dont know as of yet what will fit for keeping the a/c. I will find out the size of it once warmer weather comes back.
~Rich
92 T-Bird 5.0HO(yeah I know it is over an 88 but I like this forum :D )
Upgraded exhaust 2.5" to3" to 2.5" duals and single 3" hi-flow cat, deleted smog and a/c, cold air,ported mass air(for now).
upgrades to come-T-5 swap,3.73gears,Gt40p intake&heads,cam.
in addition, you can also remove the idler pully, grind off a 1/4'' on the stop where the pully lever hits.  that also gives you a wider range of belt sizes.
Quote from: jcassity;246206
Well on my 92 the top bolt on the altenator would rub if not for the idler pulley off-setting the belt.
~Rich
