Topic: installed 2008 f450 badges on my 96 f350 (Read 855 times) previous topic - next topic
they look really cool..im also installing the 40/20/40 seats from a newer superduty.....my wife is driveing a 2008 ford f450 repo truck for one of my buddies...and im jelious so i must bulid my own lol:hick: and yes i had to cut them to fit in....but i got them for $40.00 verses $200.00 that ford wanted or i could have orderd the stick on type for $150.00...but these are better pluse there functional as they do releave heat from the engin compartment
shagy................  did you get the seats in?
Quote from: mywifeskitty;245204
no remeber the one s i showd you....well they came from an 03 f150 and are about 4 or 5 inchs to tall and i cant modify them...i need ones from a super duty they sit lower pluse i already know how to do the brakets...ill half to call the place i got those from on mon and send them back for super duty seats:mad:
that sucks.... at least you told them to send you the super duties... they shouldn't give you too much problem swapping them out
btw, thanks for the swaybar links, i ended upo replacing them both, but the master cylinder was wrong....  it has 3 lines that hook to it, mine only had 2.... oh well, we tried :)
can you block one off...i didnt realize there were three lines...are you sure its not for the fluid levle light.there should be 2 holes on one side and one one the other for the sensor...the sesore could be missing
