Topic: converting from EFI to Carb (Read 1413 times) previous topic - next topic
What is involved in converting an 88 std 5.0 to a carbureted engine? Any advice would be great. Can the std cam still be used? Distributor?  The trans being used is a C4. Thanks for the help.
Re: converting from EFI to Carb
OK you'll need an intake, carb, distributor, ignition module, and coil.  You will also need to rewire a few things as your chassis is setup for EFI and not a carb.  Your car will turnover but you no longer have a wire harness to carry an "ignition on" power lead from the inside of the car to the ignition module.  Obviously the car will not start without an ignition lead to the module.  You will also need a fuel pump, either mechanical or low pressure electric.  A standard cam can be used.
This engine is going to be used in a streetrod so the original wiring will not be used. The carb and manifold are a given but am not sure about the cam. We want to use an old style points distributor with Petronix upgrade. We will probably go to a mild cam upgrade, nothing radical. We want to make it a basic 5.0 carburated motor. K.I.S .
Thanks mj, that was just what I was looking for.
