Topic: 255 walbro (Read 1144 times) previous topic - next topic
255 walbro
can a stock FPR handle a 255 pump...
255 walbro
Yep, it just dumps all the excess back in the tank.
Matt
255 walbro
Quote from: 5.0 bird;244647
I've heard from many sources that the stock regulator diaphram will allow extra fuel to pass by at idle and fuel pressure will actually creep up.  Why do you want/need a 255?
On a side note, my Kirban adjustable just took a shiznit.  I have to pick up a new one tomorrow.  I run a 255 Wabro with 24 pound injectors set to 48 PSI without vacuum.
255 walbro
The factory fuel pump died, and I didn't wanna pull the gas tank again when I build the H/C/I motor for it eventually.
Matt
255 walbro
I've been running a 255 walbro on the stock fpr for about 2 years now with no problems. I say go for it
