Topic: column shifter removal (Read 1198 times) previous topic - next topic
Does anyone know how the column shifter comes out? I just swapped in the floor shift unit and would like to remove the column one. I figured I would ask before I ended up breaking something.
take out the panels that cover the colum, then there are some hex nuts that hold it on.
http://www.coolcats.net/tech/advanced/floorshift_aod.html
Thanks.I figured I would ask because I know a lot of the interrior trim pieces, the clutser bezel and such have to be removed in order to get the column covers  off. I just didn't want to go through the trouble just to find out I need a "saws-all" anyway.
When I did the swap on my blue car,I removed the shift lever,left the rest on the column and removed the linkage under the hood.
Vinnie, howd oyu remove the shift lever? I can feel 3 screws which are on the back side of a bracket that the lever slips though. I can also see what appears ot be a kind of set screw which goes all the way through the shift lever itself. Not hex, not star driver, I cant figure out what goes into it. Is it one of those push spring pins? Its round on one side of it and then it turns to almost square, its tiny thought and it very hard to see. I just want the  column lever out of the car.
I remember it being hex, and there are only the three on the top. I would just pull the whole colum out and then bend the shift lever out so you can get to all the screws.
I THINK I cut it off with a strong Dremmel and a cutoff wheel.The new column pieces covered the rest.The Sport had a console shifter from the factory.
