Topic: big block (Read 3853 times) previous topic - next topic
big block
anybody out there put a big block in a 87 -88 cougar looking to put a 429 in a 87 cougar current v6
big block
no, i think you would be the first one. sounds kick ass!!!!1one!!
1979 Ford Fairmont
[/B]
big block
in a cougar not to my knowledge
in a bird yes
big block
same car just want to know what had to be done
big block
plenty big blocks have been done as well a some 4.6's.
what you do is pull your motor and put that one in,,lol
Could you be more vague?:evilgrin:
I think this one is always a good drool
big block
thats a 351, not a big block.
big block
do a search for some of sleeper tbird's threads. You'll find all your answers.
big block
haystack but doesnt it make you drool?? if not then i dunno whats wrong with ya :-p
big block
BB Cougar ?  I don't know of any. Same engine compartment as a Bird.
I have done 2 Fox Birds w/460
Pics on the link in my signature.
83 T-Bird 460
83 T-Bird Heritage 5.0
84 T-Bird 5.0
87 T-Bird Turbo Coupe
88 Bronco II Drag truck 302
95 Mustang GT auto
2004 F-350 CC Dually V-10
big block
just wondering what needed to be changed out like motor mounts trans mounts
big block
The trans mount for an AOD can be re-used if you use the double hump trans crossmember. the AOD mount bolts right up to a C-6.
The motor mounts will be a real pain if you use the 87-88 unique crossmember.  I had to make custom motor mounts to fit the 460 to my 87 TC. It seems it would be easier to switch to a V-8 Mustang K-frame so you can buy the standard 460 Fox Swap mounts.
Is this going to be a drag only car or street driven ?
83 T-Bird 460
84 T-Bird 5.0
95 Mustang GT auto
big block
its 86-88 for the k-member.
The 83-85.5? had the same k-memeber and mounts as a mustang.
big block
its going to be a street strip car thnx for all the input
big block
Quote from: 83-88T-Bird Guy;244455
I concur.  The big block may have clearance issues besides the mounts if going with a stock K-member.  Like exhaust, oil pan, etc...not impossible, just more difficult, as 83-88tbirdguy can probably attest to.
1987 TC
