Topic: How important is this hose (Read 1433 times) previous topic - next topic
1988 tbird 5.0 Ok so while removing the exahust i broke a small 1/2' to 3/4' tube that comes off of the exahust and back up to a line kinda runs parrell to the trans dipstic. What should I do I dont really want to replace the exhaust can i just plug it.
87 TC
Sounds like a thermactor line....
ok so what is a thermector line and what does it do
87 TC
walker #35574 is supposed to be a replacement
you'll prolly have to replace the check valve also unles you can seperate the crimped connection
Delete the smog stuff,get a short belt,done.
Yeah. LOL.
I do actually still have my air pump, same belt, but getting rid of the piping and the lines going to the heads made it so much better to work in that area. Space ftw.
Space FTW X2 !!!!
pinch off the line at the exhaust with vise grips
short belt per below or see my diy link above my sig
