Topic: windsor block measurements ? (Read 1368 times) previous topic - next topic
I threaded two longer bolts into the motor mount bosses on a 302, and measured between them at 13 1/8" side to side.  Can anyone confirm this?
Also from the oil pan up to the boss at 1 5/8", 7" front to back, and the K member on an 87 TC at 16 5/8".  That makes a 1 3/4" angle outward, each side,  if the 302 is indeed centered....but is it?
1987 TC
And then today in the daylight, I see the one side is offset from the other, so 13 1/8" isn't exactly perpendicular with the crank.
1987 TC
no, the motor isnt centered. its offset a touch toward the pass side.
1979 Ford Fairmont
[/B]
Quote from: 32VFoxBird;243506
Ya mean Mopar wasn't the only one to do that????
5 Mopars, an S-197, and the Turbo Twinkie[SIGPIC][/SIGPIC]
Just a little update for all those that don't care.  It appears my 400 has the same boss locations as the 302 only they're not drilled or threaded. And the ones that are, are at a 45 degree angle and with the extra bolt hole above.  So with some finaggling (sp?), I've come up with an offset of 11/16" to the passenger side....should be the same for all engines,  no?  and AFAIK, the 460 is the same as the 400 mount (bolt hole locations), only spaced outward differently because of the big block, right?
Anyhow, I'll be getting some steel from work soon, and will get to putting them together.
1987 TC
Quote from: HAVI;243479
The motor mount on the pass side is closer to the firewall than the mount on the driver side.
This was my million dollar issue with my solid plate mounts as to where i should drill the one single hole.
Since at the time, finding the 302 mounts was difficult for me, I made my own which are not offset but flat using 1/2'' plate steel.  I lost in the hood clearance game if I had the huge upper but with the carb intake it was no loss.
Well, Ford would never make it easy, lol.
1987 TC
OK, here we go again:  I brainstormed something different this time.  I put 2wd truck 302 mounts on my 400 block, which put's the capture bolt at a straight up and down angle.  I then dropped onto a block of wood to leave an imprint, and measured the center to center at 12.63".  I then disassembled Chuck's type 6 mounts, and put the lowers onto the K-member.... I hope I put them on right, lol.  So I measured the hole center to center at 17.25".  I dropped the block w/302 mounts down into the engine bay, and set the passenger side bolt right into the lower mount hole, and naturally the driver side was off roughly 4.63" or so.  So I'm guessing for starts, I could just lay in some flat plate with holes drilled to match, and go from there (thickness will determine height).  Thoughts, comments?  Anyone with the correct measurements between mount bosses yet?  I know there's some slop designed into the K-member for adjustment, so it may not be totally accurate.
1987 TC
Well, I think I got one figured out.  Just need to fasten everything down, and maybe even tack some welds between the mount and plate.
1987 TC
