Topic: rear end ? (Read 1533 times) previous topic - next topic
rear end ?
from looking at this pic would the teeth on my ring be worth using?
rear end ?
What did you do to chip them off like that?
I chipped the inside of my ring gear when my differential blew up & decided to use that as an excuse to get the 3.55's that I've wanted for a while (running out of gear at the track). I would get new gears if I were you - why chance it?
rear end ?
then i will use that as an excuse to get 3.73 or 4.10 in a week or so. is the counter shaft the same for 3.45's and 3.73 or 4.10?
rear end ?
Do you mean the pinion gear?
88 TC with 93 GT 5.0 (.030 over), XE266HR Compcam, SVO 1.6 Roller Rockers, BBK underdrives, BBK 1 5/8" headers, 2 1/2" exhuast with Americian Thunder Flowmaster lers. Tremec 5 speed and 3.73's and alot of other goodies to list.....
rear end ?
Quote from: blackcougar71;243312
Quote from: SR71TC;243349
If so...no.
rear end ?
If, on the other hand, you're talking about the cross-shaft, then I think if you stick with Ford Racing gears the same cross-shaft will work. Also, setting up the pinion depth is much easier if you're replacing OEM gears (or even other Ford Racing gears if they were properly set up) as the shim calculation becomes much easier.
