Topic: Correct timing? (Read 1633 times) previous topic - next topic
Correct timing?
Ok, I have a stroked 302 with an MSD ignition with a mallory distributor and I am trying to find out the correct timing for this engine, can anyone help with this?  Specks on my engine are in my sig.
[SIGPIC][/SIGPIC]1987 Turbo Coupe
LenTech Strip Terminator Valve Body AOD, 302 Stroker (cid 347) 10:1 Compresion
Ford Racing Cast 3.40 Crank Balanced, Pioneer Forged 5.4 Rods, Mahle Flat Top Pistons 4.40, Edelbrock Performer RPM Alluminum Heads
Ford Racing 220 Duration 500 Lift Cam, Edelbrock Performer Intake Manifold , Edelbrock 800 cfm Performer Carb
Flowtech Headers, KYB Adjustable Shocks, Dyna Max Exhaust
355 Posi Rearend
Correct timing?
I don't think your going to get a specific number,You may have to add timing till it pings and back off from there.
Correct timing?
I would recommend starting at around 28* TOTAL timing and see how it runs.
Good luck,
Don
Correct timing?
Finally got her timed right.  Timing was set at 30 deg BTDC, way to much.  Played around with her and finally got a good timing on her, she likes it at 16 deg BTDC at a total of 38 degrees.  She runs sweet now.  One thing I did notice, the timing chain is a bit stretched, couldn't keep the timing line in one spot it kept bouncing up and down a bit.  Need to put a new one on before it becomes to late.
355 Posi Rearend
Correct timing?
Quote from: CustomT;247401
You put all that money into that sweet ride of yours and you didn't replace the timing chain?  Come on man.  You know better than that.  It would be a shame to have an engine like yours trashed because of a $40 part being reused.
Now.  Hold your hand out so I can smack it!
William
Correct timing?
you may be off a tooth because of the stretch.
you should find #1 TDC by turning the crank in its normal running rotation and only then drop in the dizzy.
If you rotated the crank in both directions to fine tune the harmonic pointer, this is the reason you may be off one tooth.
Correct timing?
No, I turned crank in its normal running rotation so I know the chain is stretched.  Now just have to change the chain.
I know, I know, don't know what I was thinking when we built it.  Guess for whatever reason we just over looked it :punchballs:  and yes I do know better than that, must of had a few too many beers at that point :o  Got the car parked till the new chain arrives and I can change it out.  Last thing I want or need is it to bust while I'm running down the road.
Consider it smacked:beatyoass:
355 Posi Rearend
Correct timing?
That car sure is perdy.  Do you ever drive that thing?  It looks like you leave it in the garage, with a car cover over it all the time Dude.  :D
William
Correct timing?
Quote from: 88 Blackbird 5.0;247473
LOL, she is my daily driver.  I try to keep her clean and happy as much as possible.
355 Posi Rearend
