Topic: Assorted Cougarbird stuff for sale -- Update 3/20/2010 (Read 5097 times) previous topic - next topic
Are the cam, springs, locks, and retainers still available?
Lead me. Follow me. Or get the F#CK outta my way!
1988 Cougar
(the $360 beater)
Yes they are ;)
How much more aggressive is the cam you're selling than my E303?
Many would compare theTFS stage 1 to the b cam.
The lobe profiles between the two are very similar.  Install it with a 4 degree advance in some GT-40's ( check PTV of course ;) ) and you'll most likely notice a slight increase in MPG.  It pulls hard up top.  Almost stock idle when I dialed it in @ 900 in park....
It likes a 2800-3000 stall when you put it in front of an automatic.  Trick Flow say 22-2400.  That's NOT enough.
More than my flat tops will allow.LOL.
TFS-1 cam specs:
Intake Duration at 050 inch Lift: 221
Exhaust Duration at 050 inch Lift: 225
Duration at 050 inch Lift: 221 int./225 exh.
Advertised Intake Duration: 275
Advertised Exhaust Duration: 279
Advertised Duration: 275 int./279 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.499 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.510 in
Valve Lift with Factory Rocker Arm Ratio: 0.499 int./0.510 exh. lift
Lobe Separation (degrees): 112
E-cam specs:
cam lift.311 int exh .311
valve lift .498 int exh .498
max lift intake 110* exhaust 110*
valve setting. .000 intake exhaust .000
cam timing @.004 tappet lift
intake opens 28* btdc closes at 74* abdc duration is 282
exhaust opens 68*bbdc closes 34* atdc duration 282
cam timing @.050 tappet lift
intake opens at 0* btdc closes 40*abdc duration 220
exhaust opens 40* bbdc closes 0* atdc duration 220
Similar duration@ seat and @ .050"; the TFS has a slightly higher ramp rate and a bit more dwell over the nose.
When your valve(s) are open -- either the exhaust or intake -- where is the piston in the bore?
Don't rule it out 100%...
Do you know what your PTV clearances are as of right now?
Bumpage -- New Price $185 shipped to lower 48 for cam/springs/locks/retainers.  :)
Would this be something I might want for my car?
That all depends on the rest of your setup to be honest.  I would NOT recommend this cam for e7 heads.
What are your plans?
Reply #39
I have been looking for a diff set of heads (GT40) for the 87, since the vert will now be mainly a cruising car. Thinking mabe I could put a little more muscle in Project Evolution
Reply #40
It would work, but be even better if they were ported....
Reply #41
im guessing the piece around the column that has the lil cable to let you know when your in p,r,n ect....  i know  i just broke mine when i did the 199mph speedo conversion=]  its amazing how well (and good) it looks seeing it hit over 85 mph digital
Reply #42
Bump -- Items are in first post ;)
Thanks for looking!
Reply #43
Bump.
$170 takes the cam/springs/locks/retainers  ----That's with shipping.
Reply #44
Sale pending on cam/springs/locks/retainers  :)
