Topic: Can I use wheel spacers if.......... (Read 2059 times) previous topic - next topic
I know that using wheel spacers is tabo for some people, but here is my idea. I plan on buying some race tires soon, looking at some used Hoosier 245/50/15 R compound tires for my 10-holes. Can put a 1/2 spacer in the rear on the if I replace the stock studs with longer ARP studs, and can I use a 1/4 spacer in the front (to get the tire off the sway bar in turns) on the stock studs or will I have to replace them with ARP studs. I would like to use this set-up for the street but defenatly want to use it for the track. Any thoughts!
Re: Can I use wheel spacers if..........
I'm wondering if that's an option for me too.  The 8.8 that's going into my '85 is from a Mustang, so it's narrower.  It's either longer studs and spacers or swapping the axles out.
http://www.maximummotorsports.com/spacers.asp
they sell spacers, and have install directions, which should help the topic a bit
thanks man that helped alot, does anybody have the knurl size for the stock brakes on a '86 T-Bird. The guys at summit or ARP don't know there ass from a hole in the wall it seems.
