Topic: Annoyed (Read 2165 times) previous topic - next topic
Annoyed
OK i bought the wireing harness for the t/c ad the installation kit and hooked it all up and now the radio will turn on and stuff but it does not put sound out through the speakers.  OK i have the premium sound system and i read your suppost to unhook the amp and your suppost to to un plug that stock grey plug from inside the dash and plug in the new aftermakarket harness.  OK one thats false, there is nothing to unplug beside the stock radio plugs and i un hooked the amp in the back and i still have the same problem!  Ehat do i do!
Annoyed
Did you find the second speaker plug taped to the harness behind the EQ(upper) opening??? This connector is used when the amp in trunk is disconnected... And it must be unplugged or you get smoke...
Annoyed
No unless im looking in the wrong place. all i see is the grey and black harnesses that are just wire going well into the dash
Annoyed
My second speaker harness plug was taped up and tucked so far up in the dash, it took me nearly an hour to find it. It was up over the glove box...then, after I found it, I had to work it for at least another 15 minutes just to get enough slack to reach the radio! It's definitely up there...but they really tuck it away...you really have to search for it--plus you're doing it blindly (at least I did--couldn't hardly get my larger than normal crainium to fit under that dash).
