Topic: efi to carb (Read 1177 times) previous topic - next topic
efi to carb
i got a 5.0 ho motor that im going to put in my new car. im thinking about making it carbed insted of efi so its easy to put in dose any one think its a good ide and what size carb should i use?
88 5.0L aod with duel flowmaster and speedo mod
88 5.0L H.O with 5 speed R.I.P
87 3.8L no trans. geting h.o and 5speed (project never ending thunder) started it as of 8-14-10
96 bronco xl 5.0L 5 speed man4x4
:birdsmily:
efi to carb
im thinking about this too...  what i worry about is hood/filter clearances.
efi to carb
ya me to but i have tc hood to go on it that i was going to make a thing for the ram air to work with the carb
:birdsmily:
efi to carb
right now that car has a 3.8 carbed and theirs no problems with that
:birdsmily:
efi to carb
assuming a mostly stock 5.0 with a carb, hood clearance shouldnt be a problem.  my 83 isa 5.0 cfi, with a summit filter.  hieght is about what it would be with a carb.  hood clearance is fine.
as for carb size, on a 302, you honestly dont want anything bigger than a 600cfm.  again assuming stock.  on a mild setup, such as a good intake, headers and exhaust, cam, prehaps some mild porting, than a 650 is in order.  dont forget to check the timing, and dont forget to tune the carb.
Quote from: ?;247173
Screw you Ford... I'm going to get a ranger riding a mustang to restore your focus on the expedition needed to escape from the edge of bankruptcy.
Quote from: random im message;385099
need to pretend to get some awesome wheels for my invisible cars so i can pimp hard in my dreams at night...
efi to carb
I did the switch many years ago. However, just last year I made the switch from the Ford 2 barrel to and Edelbrock 4 barrel. Clearance wise I have no problems. Here is what I used.
The cam is crane fb-272 H10 Energy cam and lifters
adv. Dur.
272 INT. 272 EXH.
.050 Dur.
216 INT 216 EXH
Carb Edelbrock Avs Thunder series model 1806
Edelbrock Performer RPM intake model 7121
The carb seems to be a little big, in hind sight I probably would have went with a 575 CFM. It runs rich, I just need to get off my :shakeass: and put smaller jets in the primary. But for as often as I drive it, I haven't bothered. Its just a cruiser, so loosing a little performane hasn't bothered me yet.
