Topic: general exhaust ???? (Read 1731 times) previous topic - next topic
this may be a dumb question, but is it harmful to a motor to run it (just at idle) without any exhaust manifolds or exhaust connected?:mullet:
FOXLESS!!
1994 Lincoln Mark VIII
not a good idea. you could warp the valves, with having absolutely no back pressure.
1979 Ford Fairmont
[/B]
what about with just the headers? would that make any difference?
FOXLESS!!
Here's a question. Exactly how long do you need to run this for like this...?
just long enough to see if the exhaust was the problem i was having maybe about 3 or 4 minutes
FOXLESS!!
and why would removing exhaust solve a problem?
1979 Ford Fairmont
[/B]
cats were smoking, believe they were clogged and not releasing pressure from the engine
FOXLESS!!
Depends....With open headers in place I'd say no as I've done it.
Excellent discussion on the topic here:
http://www.eng-tips.com/viewthread.cfm?qid=225069&page=1
NO.  It's the possible lean condition that causes the POTENTIAL problem.
http://www.foxtbirdcougarforums.com/showthread.php?t=19019
http://www.popularhotrodding.com/enginemasters/articles/hardcore/0505em_exh/index.html
FWIW anybody who states backpressure is needed in an exhaust should shove a banana up the pipe(s) on their vehicle and take it for a drive.  Let us know what happens ;)
:rollin: :laughing: Yea that is thrown around SO much. Only time it might actually be relevant is with 2-stroke engines, but even then I don't know a whole lot about it.
did you drive it with open headers or just let it idle?
FOXLESS!!
Drove it 30 miles....non stop to where the welding machine was ;)
That was about 10 years ago.
backpressure......:mullet: just makin sure i wont screw anything up
FOXLESS!!
