Topic: sequential light ? (Read 1757 times) previous topic - next topic
sequential light ?
put my sequencer unit on the 88 a while back.first
time i got caught after dark was last night . wife
wanted to know about the flickering light. every time
you put on the signals either way or hit the brake
the light out arrow flickers on each time.all the lamps
are working and operating correctly. any thought on why?
everything works and show being correctly wired. if
anyone will have something weird happen its me.
[irvies law]--thanks!--irv
its the light out section in the monitoring system
-88 XR7
sequential light ?
Sounds like the modification has reduced the current draw of the brake/turn signal lights.
With a stock setup, here is how it works.
With both bulbs on one side working, the lamp-out warning module "sees" 0.5 volts dropped across a resistance wire in the light circuit.
With one bulb out the module sees 0.25 volts dropped across the resistance wire. This causes the module to turn on the lamp out warning light.
Does this sound like something you want to try and fix?
It will require figuring out what size resistance to put in the circuit to satisfy what the module wants to see.
sequential light ?
am i the only one that had this happen? everything
works fine.hasnt anyone used this on anXR7? they
all have the t/lamp out function.--irv:D
sequential light ?
If you bought it from me you might try adjusting it a bit (if you bought it from others it probably isn't adjustable). The Ford lamp out system is quite unpredictable with sequencers - I had 'em in my '87 Sport with the systems sentry and the light didn't come on, and for the vast majority it's the same, but a few have had the issue (and as far as I know every one of them has been able to fix it by twiddling with the adjusters, at least I haven't heard otherwise)
sequential light ?
i bought it from you. very happy with the way everything works
what do you mean by adjusting it? dont worry. im not complaining,
just asking. its a liveable condition. must be a screw on the module
i need to turn? any info appreciated. thanks!--irv toms:D
sequential light ?
Yes, there's a screw on the module. Clockwise slows it down, counter-clockwise speeds it up. Just try adjusting it either way to see if the light in the dash goes out
sequential light ?
thanks Carm!--irv
didnt know there was an adjustment
pbobably was in the instructions[oops]
