Topic: Air inlet tube questions (Read 883 times) previous topic - next topic
When doing the H.O. swap, will the Mustang air tube bolt up to the cougar air box?
Can I use a cold air intake setup for a SD mustang?
Mike
the 86 - 88 tbird and cougar 5.0 box is the same as the
86-93 mustang 5.0. matter of fact it has a tbird[E6SZ]
part #.
If the air inlet tube is from a SD car you're good.Mass Air tubes are obviously different due to having the meter in between two seperate tubes.
