Topic: Dyno Numbers! (Read 3932 times) previous topic - next topic
Nice to see another Lincolnite on here
Hello,
    Nice looking car, with good numbers also.  I own an 88TC, and was wondering how much the dyno time ran an hour where you went? PM me if you can.
Thanks
Dyno Numbers!
IMHO, intake spacing is about cooling the air in the intake right (insulating heat form the upper intake)?
Well at WOT the air in the manifold is moving so fast that it cools the the manifold very quickly and removes the heat, so there's no heat to protect it from.  I can't imagine that it is doing much.
Dyno Numbers!
Quote from: thunderjet302;240221
DO NOT PUT THE ACT SENSOR IN THE AIRBOX! HAVE THE HOLE TAPPED IN THE INTAKE MANIFOLD AND PUT IT IN THERE! Get it? ;)
I get it. I forgot to have the boss tapped when I was building the motor. I did some reading over at the Corral and came to the conclusion that it doesn't make much of a difference if it's mounted or not. I will have it done when it's out this next time regardless, I might smooth and polish the intake too. Oh, and I would never have put it in the air box
Quote from: SR71TC;240229
You know I never got around to getting my EEC tuned, maybe it is time.......
Highly recommend it
Quote from: jangus;240240
Thankyou, PM sent
Quote from: xjeffs;240259
Yeah, I agree that there can't be doing ALOT. I don't think the air would actually make a difference in the metal temperature, but the metal would have less of an impact on the incoming air that spends less time in the manifold. Heat still transfers one way or another, if the air cools the intake, the intake is heating the air; if the intake is at a lower temp, then it will cool quicker.
GT40p 5.0 w/ vortech @ 9.5psi, 400rwhp
Dyno Numbers!
Quote from: V8Demon;240000
What was the part # on the springs?
I had to find the order confirmation from 2006
Ford Racing M-6513-A50
Valve Spring OD - 1 500" ID - 1 006"
Seat Load - 100 lbs @ 1 820"
Open Load - 240 lbs @ 1 400"
Dyno Numbers!
These?
http://www.fordracingparts.com/parts/part_details.asp?PartKeyField=44
If I'm not mistaken, those are stock apparel from the '93 heads.....
You'd have been better off with your P valves FWIW....
