Topic: 245/50/16 Tires (Read 2713 times) previous topic - next topic
245/50/16 Tires
Has anybody ever exspiremented with 245/50/16 on there T-Bird or Cougar. On my '86 I noticed that the tires are rubbing the front sway bar when you go lock to lock. Just want to know if its normal or not, I'm banking its not.
Re: 245/50/16 Tires
Haven't had them on long enough to notice.  I have noticed some noises in the front, but figured that it was the struts, creaking from sitting in my garage for two years.
Jeff :canada:
Re: 245/50/16 Tires
Got them on my car. I had to put a 1/4in spacer in to keep them from rubbing the struts. I fixed that and now they rub the inner fender when I turn or hit a hard bump.
Which you can see it also sits low from these pics.
Re: 245/50/16 Tires
I had some on my old 83 5.0 'Bird...no issues and only occasional rubbing of the driver side tire on the fender lip.  On 16x7" wheels.
Re: 245/50/16 Tires
You think it may have something to do with the tires themselves, I have spoogeho 712's and people say that thoush tires are a little taller and wider than other 245/50's, or is that all BS.
Re: 245/50/16 Tires
I run 245/50/16's on my TC all the time. The only issue I run into is a very slight rub when making a slow, hard right hand turn. like going into a parking space. Car is stock height, and the tires are spoogeho's. Pictures of the fron and rear in these links:
http://community.webshots.com/photo/286291390/299149059XwkzuY
http://community.webshots.com/photo/286291390/299149203xnaYTv
Bob Myers
