Topic: Fog Light Issue (Read 1053 times) previous topic - next topic
Fog Light Issue
I have a 88 tc with factory fog lights and I just noticed on the way home that they were not working so I pulled the fuse and it was blown so I put a new one in and it worked for 2 seconds and then it blew so im thinking I have a short? or the switch could be bad? I did a search but did not find anything, and im not the best with electrical issues so any help is appreciated thanks for the help
-Vic
Fog Light Issue
Could be one of the lamps,are they factory???
Is so try disconnecting one at a time and installing a new fuse that will tell you which one.
Also try with both lamps disconnected and that will tell you if you have a short in the wiring.
Fog Light Issue
ok thanks i will give it a try tomorrow
