Topic: Dew wipes & Weather stripping (Read 2390 times) previous topic - next topic
Ok, I have read the sticky post.  But I'm still a bit confused.  I have an 85 thunderbird without vent windows.  Had a set of those doors, and gave them to my cuz years ago.. arrgghh.
I need to replace my dew wipes on both sides as well as the weather stripping.
What do I need? and Where do I get it.
Is pop riviting difficult?  Is there a specific area I need to rivit?
Thanks all!
===85BIRD===
:birdsmily:
Refer to the sticky thread to get the part numbers for the dew wipes. They can be ordered from JC Whitney.
They come long enough to fit a door without vent windows; I had to trim them for my doors.
Pop riveting is easy. Once you have aligned the replacement dew wipe to the trim piece from the door, you can drill an appropriately sized hole through the trim piece and the dew wipe, which has a metal bar inside for support, and insert the rivet into the new hole. The gun will compress the rivet and secure the two pieces. Do this a few times down the length of the assembly and you should be all set.
Make sure you have it all lined up while you're doing this.
Once you take everything apart, it should become obvious how you will proceed.
http://www.foxtbirdcougarforums.com/showthread.php?t=8969
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
cougarcragar - Ok check, I'll get the weatherstripping.  Sounds straight forward.
347Thunder - thanks, that was the sticky that l was referring to.
I hope I can get the dew wipes somewhere too.
===85BIRD===
:birdsmily:
Thanks fellas.
Now, any idea where that weatherstripping can be found new?
===85BIRD===
:birdsmily:
http://www.jcwhitney.com/autoparts/ItemBrowse/c-10114/s-10101/p-100000166883/mediaCode-ZX/appId-100000166883/Pr-p_CATENTRY_ID:100000166883
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
talk about spoon fed...
True it's just I had them saved because I am waiting to do mine
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
Quote from: 347Thunder;239326
Its not a bad thing. Its always good to get help, but it was linked to like three times before you did a direct link.
Anyways good luck, take some before and after pictures.
:bowdown: Thanks for the help.  It is GREATLY appreciated !!:bowdown:
:burnout:
===85BIRD===
:birdsmily:
200825 83-86 THUNDERBIRD, COUGAR, 84-87 LINCOLN MKVII $200.00
Um....no thanks. That's what most people pay for their entire cars. ;)
Appreciate the link and all, but you'll never convince me that two hunks of rubber are worth $200.
You could buy a handful of good doors for $200
Ok, got my weatherstripping and dew wipes coming!  I cannot wait to re-seal these windows.  Anyway, one final question....
I still need the window channel weatherstripping for a non vent window car.  It sounds as if they only make them for cars with vent windows??
===85BIRD===
:birdsmily:
