Topic: 8.8 TurboCoupe Axle Swap (Read 1561 times) previous topic - next topic
I picked up an 8.8 TurboCoupe axle with 3.73 gears and rear discs. Has anybody here swapped one of these in place of the 7.5? I would like to know what you recommend for a Brake Booster, Master Cylinder, and Prop Valve. for the swap. My car currently has the factory rear drum brakes.
1988 Thunderbird
306 HO w/ A9P processor
AOD w/ Transgo Reprogrammer
245/50/16 Tires on Snowflakes
Yes several people have swapped them and even made threads about it.
Did you take the time to search?
93 COBRA master and booster
FMS adjustable prop vavle.
Thanks Dominator. Where did you locate your adjustable prop valve? did you have to cut the brake lines to install the prop valve? Do you feel the upgrade to rear disks was worth it? I've thought about just installing my 7.5 axles, drums and backing plates on the 8.8 axle to make things easy.
1988 Thunderbird
Quote from: 88BlueBird;239027
Can you even do that? Wait I guess you could but why not just find a rear from an 88 XR-7?
That does not work for the 86-88 7.5 rears used in the Tbirds/Cougars.
Check out the 2 or 3 threads at the beginning of this section that already cover that.
Quote from: thunderjet302;239033
I have an 88 XR7 8.8 10" drum rear I'll trade ya.
1987 TC
