Topic: aftermarket seats? (Read 2002 times) previous topic - next topic
aftermarket seats?
I made a set work, and I even have have the electric adjustments working
1985 Thunderbird TC
2.3l .03 over,Ported and polished Head and E6 Manifold, LA3, T3/T4 Hybrid Turbo, Stinger FMIC, Forge BOV, Full 3" Exhaust, Essy Timing Gears & UDP's, BBK 255lph Fuel Pump, Kirban AFPR, Kirban Short Shifter, K&N Cone, Forced4 VC Vent Kit, PA Performance 3g Alternator, Energy Suspension Bushings throughout, CHE LCA's, SFC's [/LEFT]
aftermarket seats?
You can make just about anything fit.
aftermarket seats?
I have ones like that in my car but all black
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
aftermarket seats?
So does he have to take the slider bracket off the bottom of the seat and fasten the stock sliders to the seat frame?  I was considering a similar swap possibly.
aftermarket seats?
These are my brackets the drivers is a fixed mount because Moroso(race track) complained how woblie the seat was(py loose track). I have to change the passanger because the aluminum is too thin.
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
aftermarket seats?
More pictures of the tracks
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
