Topic: stall and stall again.... (Read 2938 times) previous topic - next topic
Hey guys (and ladies)...my 88 xr7 is idleing really rough, and every time i start it it bogs out and dies.. when it does idle it almost stalls out and then picks up again,but then bogs out again... it also stalls when i turn the wheel to take a sharp turn... please help i know someone has had this problem b4... thanks, i apprciate your help and value everyones opinion.
[/IMG]
Just enjoyin the ride!!!!
Codes
What's the info on your car?Details.
Fuel pump.
Quote from: kitzdnm;238930
Codes
Thank you; at least SOMEONE said it...
How's it run while in gear with a load on the motor out of curiosity?
Ask but don't partite?
iTs stock 5.0 135k only mod is a cone intake. Runs the same with load but not as bad. sorry kitz had to take care of sumthin. other than that my dash is dissconnected but still in place with evrything connected(wiring n such) no brackets.-long story
[/IMG]
All your plug wires connected? and good?
Yeah i replaced them a few weeks ago and the plugs. My power steering pump is really leaky ... i was wondering if a bad pump could put more stress on the motor but my belt doesnt squeak....
[/IMG]
TPS?Timing?IAC?
Ive never touched the distributer, or messed with the timing. its always ran great...when its beeen running for a little while it will idle fine at red lights but when i hold the brake and turn the wheel, she stalls. im gonna do a compression check this weekend and see what happens, im really hoping that its not somthing bad like a bad valve or so... theres no lack of power at all just in low rpm it doesnt  run steady.
[/IMG]
Is it blowing any smoke from the exhaust?Losing any water?Maybe a head gasket going bad......small,tiny leak.
could also be a slipped tooth on the timing... If you pull codes you'll be 90% more likely to get it fixed. I never pulled codes on my car and fought to get it fixed by replacing everything, and it ended up being a vac line on the map sensor. The difference is about 10mpg.
no smoke or water... and how do i pull codes in the 88?
[/IMG]
http://www.therangerstation.com/tech_library/OBD_I.html
