Topic: Brake caliper compression (Read 1761 times) previous topic - next topic
it has been a very long time since i have replaced brakes on a vehicle, so please excuse what is probably a very simple question.
what is the best procedure for compressing the brake callipers? i have had cars that you had to rotate the center which compressed them, and some that i used a C clamp on. for these cars, what is the best method? thanks!
[SIGPIC][/SIGPIC]:cougarsmily:
You only need to compress and rotate the rear disks.  The fronts you just need to compress.
ok, thanks!
another suggestion is take a c-clamp and use the old brake pad over the piston when compressing... i have had pistons crack otherwise.  just a tip.
Quote from: the_intimidator03;238958
That's my method on the front.
On the fronts I take a big screw driver and compress it before I pull the caliper.
its always a good idea to crack the bleeders loose when you compress the pistons to stop from pushing any dirt that gathered in your caliper back into the system. especially if you have ABS
1988 Thunderbird sport
2004 Ford F150 Lariat
2008  Chevrolet Cobalt Sport
1988 Thunderbird LX - sold
