Topic: hood question (Read 1996 times) previous topic - next topic
hood question
i'm putting a turbo hood on my lx bird and im wondering before i put it on if i need to do any mods to make it fit?
thanks LxBird
hood question
If it's a 5.0L then yes.
You have to remove the front black a/c bracket and grind/cut it down to where it just goes around the top bolt.
If you don't it will hit the drs side scoop and push it out of the hood when you accelerate due to eng movement.
You must also drill out the rivets for the for the duct work undernieth the hood. and remove it.
Last but not least you must trim down the front hoodscoop mounting bolts as they will hit the fan shroud.
hood question
:iagree: What he said...
hood question
What they both said let me add this if you have to grind down the A/C braket paint it so it does not Rust since the hood scoops will let the rain and snow in.
hood question
Or block off the scoops ;)
hood question
Thanks for the info guys!
hood question
Blockoff plates.....
Right.I made block off plates for mine that keep most everything out,and aren't really even noticeable.I'm cool like that.LOL.
hood question
Quote from: vinnietbird;238999
Yeah yeah.. Vinnie and his block off plates... LOL.  I need to do something with my open scoops
hood question
The scoops on my Sport were open and I was tired of cleaning the engine and having a LOT of water go under the hood when it rained,so.........scoop block off plates.
hood question
I'm making some that are perferated, holes are 1/16". Got the material in the s ben. Although I like seeing the intake through the vents. Can we see a shot of what they look like with the hood down?
Jason
88 TC with 93 GT 5.0 (.030 over), XE266HR Compcam, SVO 1.6 Roller Rockers, BBK underdrives, BBK 1 5/8" headers, 2 1/2" exhuast with Americian Thunder Flowmaster lers. Tremec 5 speed and 3.73's and alot of other goodies to list.....
hood question
They just look like black holes.
