Topic: put my line locks on today (Read 2251 times) previous topic - next topic
along with my SS braided brake hoses.  They needed modification though before they would go in the factory brackets.  I had to grind down the little hex on the end of the hose before it would go through:mad: I used two line locks to allow me to keep the abs:headbang:
starting installation
Finished
Very cool. I need to do something similar for mine at some point.
Matt
Arent they supposed to be on the rear brakes?
no
you use them to do burnouts so you dont have to use the rear brakes and wear them out
it only turns on the fronts
Quote from: bhazard;238537
Maybe on a frontwheel drive car but thats a fail all of its own, because your line lock would be built in - parking brakes:rollin: :rollin:
Do you not figure I know what i'm doing brad?:hick:
I thought they blocked the pressure to the caliper or drum, ie flip switch to 'turn off' the back brakes.
No you dont know what youre doing dude, you put that junk tbird together with that junk turbo and header, that junk truck that dont autocross worth a .... junk junk junk.
Oh yeah heres mine, better than any junk youve got
quit your yapping and put the motor back in it.  JEEZ
Quote from: bhazard;238557
Let me know when your done i want to race your FAIL bird
KRyyyyyy
sad thing is is that I have made barely any progress to my bird. Im stuck on assembling my replacement motor, cant find the timing belt tensioner hardware (that spring and the bolts and such).
who gives a rats ass about the install....  let see some pics of them in action. ;)
LOL
I still havent wired them, rofl
Quote from: fordguy545;240050
same for me .. All plumed up in the car. but just need to wire it up...  as soon as I get my truck  home I will. the  rest of the parts are in it. and need to fix the forks on the shifter.
